Watercooling case that doesn't need modding?
17 Dec 2004
Crawley, WEST SUSSEX
Hi,
Ok I may well want to change cases from my Lian Li and I really don't have the time to mod a new case like I did with my Lian Li. So I want a case that can take a 120.3 rad, plenty of space, looks like the Lian Li (minimal etc), black for the colour um and is easy to work in.
I have been thinking of getting a MountainMods case as I like them but wanted to double check what else was out there??
You could just make ur life a little easier and pick the case u like and then instead go to ur local laser/water cutting company (they are everywhere). But really ur wasting ur money buying a mountianmods (in my oponion) as everytime i see them and then find out it cost someone it makes me feel dead inside :P. Also if u cant be bothered to even do that there are lots of overclockers competetors that will even sort out everything for u if u want. Personnally 800D doesn't sound like a bad idea just remenber even with that case ur still gonna have spare cash left over compared to a buying a lian li :P (trust me i know v2110B is damm expensive :P)
Silverstone TJ07. Ive got a pa120.3 and a pa120.2 in the bottom of mine running 2 seperate loops. Didnt need to do any mods to the case to get the watercooling in :)
