Hi all,
After a bit of advice regarding a new WC case.. so currently i have...
Deep Silence 1
2 x Coolgate CG240 240mm Radiator - Black
4 x Noiseblocker NB-eLoop Fan B12-2 - 120mm (1300rpm)
1 x EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump)
1 x EK Water Blocks EK-Supremacy EVO - Full Nickel (Original CSQ)
1 x EK Water Blocks EK-Titan X/GTX 980Ti Acetal Nickel
The problem i have is there isn't much airflow through the case and it gets hot inside (mainly due to the intake 240).
I have a 240 in the roof and a 240 at the front. Basically i'd like to a nice case with i guess a 480 at the top with a few intake fans to keep the case cool and let the rad do its job.
Currently i'm OC my 980Ti to 1500/8000 and 3770k(1.25v) to 4.5Ghz with temps of the CPU get to 80~c according to RealTemp and the GPU maxes about 60c. i feel these are a bit high?
idle is about 35cpu/gpu. (usualy UK temps about 20 or so deg).
Basically i'm looking for an excuse to upgrade my case to something nice and cool
Thanks,
Arch
Deep Silence 1
!Thanks,
Arch
