Finally stepping into watercooling. Got a 120.1 Thermochill radiator sat here ready to use and have a Swiftech Apogee coming on Friday.
Going to be cooling the setup in my sig and later on in the summer the cpu will be a quad.
The first problem I've got is mounting the Radiator which I got second hand from the MM, it doesn't have any obvious way of mounting. Any suggestions? (see pics)
The fittings are 10mm / 3/8" ID and 12mm / 1/2" OD
http://img.photobucket.com/albums/v607/The_Head/rad1.jpg
http://img.photobucket.com/albums/v607/The_Head/rad2.jpg
The swiftech site says the block is comes with both 3/8 and 1/2 fittings. Is this ID or OD? Want to use the same size all around just for conveince.
I'm still confused as to which pump would be best, Different places seem to recommend different pumps and I don't really want to spend a fortune. Just need it to be a 12v pump. What pump provides the best performance/cost for the above setup?
Also what tubing should I look at, many to choose from, everywhere from fancy stuff to generic stuff bought from the local diy shop...
IIRC I read somewhere that I want tubing with an inner diameter smaller than the OD of the fittings to insure a tight fit, is this correct?
I'll be using a T-line and wormdrive clips with this.
Any advice would be great
