After seeing the waterclcoked bundle i had to tihnk about using this rather than the H50 bundle as it seemd a good idea and a lot of the work done for me.
Note this will all go in a corsair 800d
Anyway is thisi s a 1st attempt of what i may get not sure on pump or res at the moment and barbs as i think i will need 8 for the bundle.
I really want the red tubing as i always have my keyboard and mouse set up glowing red and feel this will look really good all RED everywhere
. so anyway is this enough bits ? aswell as i guess i need even more barbs for the Res to. I want barbs i know wont leak basicly so putting abit of money into it. BTW does any1 know if putting silicon grease will help seal the tubes more ?. As i use Abbey Silicone Grease for airsoft stuff and it gives a water tight and dirt tight layer.
On another note to save somany posts does any1 now if the Creative Sound Blaster X-Fi Titanium - Fatal1ty Champion Series 7.1 Sound Card will it in any of the following s;lots ideally the orange 1 ?
. so anyway is this enough bits ? aswell as i guess i need even more barbs for the Res to. I want barbs i know wont leak basicly so putting abit of money into it. BTW does any1 know if putting silicon grease will help seal the tubes more ?. As i use Abbey Silicone Grease for airsoft stuff and it gives a water tight and dirt tight layer.On another note to save somany posts does any1 now if the Creative Sound Blaster X-Fi Titanium - Fatal1ty Champion Series 7.1 Sound Card will it in any of the following s;lots ideally the orange 1 ?
