Hello all,
Built my first water-cooling loop around 7 months ago, all went well luckily enough
Here is what the loop consists of:
EK Supreme HF Full Nickel CPU Block
EK-FC580 GTX+ - Nickel Plexi Waterblock
Laing D5 Vario MCP655 12V DC Pump
EK-Multioption RES X2 - 250 Advanced
XSPC RX480
XSPC RX240
It's come that time where I need to tear down the system change coolant and clean the loop, Since I haven't done this before I thought I'd ask a few questions before I start.
What would be the best method on cleaning the parts? I read regarding the CPU block, open it up and check for anything and if there is oxidation let it soak with ketchup for a while, then put it into a container with de-ionised water. Also will it do any damage to my Nickel block putting ketchup over it?
What about the GPU block , rads and the pump & res? Should I just re-build the loop outside the case and run it with de-ionised water, empty and repeat until the water is clear?
Sorry if these are stupid questions, Just want to make sure all the necessary producers before I go ahead.
Thanks
XSPC RX480
XSPC RX240
Thanks
