XSPC Razor GTX970/670 VGA Waterblock - Fits Inno3D GeForce GTX 970 OC @ £49.99 inc VAT
We are proud to introduce our new design for Razor GPU blocks. We have continued with the styling from our RayStorm series so you can now have a full set of matching XSPC blocks. We have also significantly improved cooling performance by reducing the fin width from 1mm to 0.5mm, this dramatically increases the surface area.
Although we have used an acrylic top for aesthetics we have a thin stainless steel plate between the copper base and the acrylic. This allows us to use LED lighting, while keeping the strength and reliability of an all metal waterblock.
The new multiport connector gives you many choices for neatly routing your tubing. We have two G1/4? ports on the front and back of the block, two on the top, plus a side port, giving 7 ports in total. The multiport connector is compatible with our new SLI flow bridge.
- CNC machined copper base
- 0.5mm fins for high performance
- Stainless steel top
- Acrylic layer with 3mm LED holes
- Brushed aluminium faceplate
- Dimensions: 172.5 x 125 x 25.5mm
- Weight: 0.73kg
- Prepared for SLI with 7 G1/4" ports
- Supports GTX670 cards
(Nvidia reference design only)
Supplied with twin LED, mounting kit, G1/4" plugs, thermal pads and thermal paste
Only £49.99 inc VAT.
ORDER NOW
EK Water Blocks FC770 GTX GPU Water Block - Acetal @ £49.99 inc VAT
EK-FC770 GTX is a high performance full-cover water block for nVidia reference design GeForce GTX 770 series graphics cards.
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC770 GTX water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps. The cooling engine now uses refined, more narrow microchannel structure to even further improve the heat transfer.
Specification:-
- Material: Copper Acetal
- Thread: G1/4
Contents:-
- EK-FC770 GTX series water block
- Mounting mechanism with screw-in brass standoffs
- Thermal pads
- Thermal grease EK-TIM Ectotherm (1g)
ORDER NOW
Aqua Computer Kryographics for GTX 770 - Nickel @ £49.99 inc VAT
Combined GPU/RAM/VRM-cooler for graphics cards of the type nvidia GTX 770 with 2048 MB RAM according to reference design.
This cooler combines the features of a graphics chip cooler and RAM-coolers in an elegant and very flat watercooler. Additionally the voltage regulators are also cooled effectively.
The kryographics for GTX 770 water block offers outstanding cooling performance and a low flow resistance. All mounting threads are equipped with spacers for easy installation and to prevent twisting the graphics card. The areas contacting the GPU and RAM modules are polished for excellent heat transfer. For the voltage regulators, a thermal pad with high thermal conductivity is included.
The kryoconnect water block series features a delrin connection terminal that has a significantly reduced flow resistance compared to the previous aquagraFX series. The terminal is fastened to the water block by three screws and has G1/4 inlet and outlet ports on each side for flexible installation. Two sealing screws are supplied to seal the unused connection threads. The terminal can be replaced with kryoconnect kits for SLI configurations (art. no. 23551, 23552 or 23553, not included in delivery).
Materials:
- Base part: Copper, nickel plated
- Top cover: Stainless steel
- Terminal: Delrin
Scope of delivery:
- Cooler without connectors (screw threads G 1/4)
- Mounting material incl. thermally conductive pad
- Two sealing plugs for unused connection threads
**Graphic card and fittings are not included in delivery, please order separately. Threads are G1/4". Thermally conductive paste is required for installation.
ORDER NOW
Aqua Computer Kryographics for GTX 770 @ £49.99 inc VAT
The kryoconnect water block series features a delrin connection terminal that has a significantly reduced flow resistance compared to the previous aquagraFX series. The terminal is fastened to the water block by three screws and has G1/4 inlet and outlet ports on each side for flexible installation. Two sealing screws are supplied to seal the unused connection threads. The terminal can be replaced with kryoconnect kits for SLI configurations (art. no. 17196,17197 or 17198, not included in delivery).
Materials:
Base part: Copper
Terminal: Delrin
Scope of delivery:
cooler without connectors (screw threads G 1/4)
mounting material incl. thermally conductive pad
two sealing plugs for unused connection threads
Please note:
Graphic card and fittings are not included in delivery, please order separately. Threads are G 1/4. Thermally conductive paste is required for installation.
ORDER NOW
Aqua Computer Kryographics 780 Ti Acryl Edition @ £49.99 inc VAT
Combined GPU/RAM/VRM-cooler for graphics cards of the type nvidia GTX 780 Ti with 3072 MB RAM according to reference design.
The kryographics for GTX 780 Ti water block offers outstanding cooling performance and a low flow resistance. All mounting threads are equipped with spacers for easy installation and to prevent twisting the graphics card. The areas contacting the GPU and RAM modules are polished for excellent heat transfer. For the voltage regulators, a thermal pad with high thermal conductivity is included.
Materials:
Top cover: Acrylic glass with stainless steel frame
Terminal: Delrin
Scope of delivery:
Please note:
ORDER NOW
Aqua Computer Kryographics for GTX 780 Ti - Black Edition @ £49.99 inc VAT
Materials:
Base part: Copper
Terminal: Delrin
Scope of delivery:
Please note:
ORDER NOW
EK Water Blocks EK-FC780 GTX Lightning - Acetal+Nickel @ £39.95 inc VAT
EK-FC780 GTX Lightning is a high performance full-cover water block engineered specifically for MSI design GTX 780 Lightning series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC780 GTX Lightning water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of nickel plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws. Original backplate can also be re-used with the use of enclosed M4x6 DIN7985 screws.
G1/4" threaded fittings can be used on both sides of the FC terminal. Flow orientation doesn't matter and is thus not prescribed.
Up to four EK-FC780 GTX Lightning water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
Enclosed:
- EK-FC780 GTX Lightning series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
- thermal grease EK-TIM Ectotherm (1g)
Made in Slovenia - Europe!
PLEASE NOTE:
- Fittings are not included! Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
- Water block ports does not align with any other EK-FC water block.
- The original MSI factory provided backplate can be re-used with this water block!
Only £39.95 inc VAT.
ORDER NOW
EK Water Blocks EK-FB KIT SR-X - Nickel @ £29.99 inc VAT
EK-FB KIT SR-X full-board water block kit is a complete liquid cooling solution for EVGA Classified SR-X (270-SE-W888) motherboard. The water blocks directly cools Intel C606 southbridge (PCH), PLX PEX8784 PCIe lane splitter controller and power regulation (VRM / MOSFETs) module of both CPUs. Please note this water block cools exactly as much heat generating components as EVGA factory cooling solution. It is medium-high to high flow water block that can be easily used with systems using weaker water pumps.
Base of the waterblock is made of nickel plated electrolytic copper while the top is made of quality satin finish acrylic material. The sealing is performed by quality rubber gaskets.
Water block is mounted with enclosed M2.5x4 DIN7985 screws and PVC washers. The 2.1mm nickel plated brass screw-in standoffs are already preinstalled and allow for easy installation.
Enclosed thermal pad is used on voltage regulator modules to improve cooling performance of the waterblock. On the southbridge and PCIe lane splitter chip please use any electrically non-conductive thermal grease, e.g. Arctic Cooling MX-4.
Enclosed:
- 3 x water blocks (2x MOSFET & SB)
- thermal pads
Fittings are optional not enclosed! Six fittings are needed to make this waterblock to operate properly. All EK-PSC fittings are compatible with this water block!
Please note:
- Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
- Fittings with G1/4 thread longer than 5mm are not supported!
Only £29.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FB KIT SR-X - Acetal+Nickel @ £29.99 inc VAT
Base of the waterblock is made of nickel plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber gaskets.
Enclosed:
- thermal pads
Please note:
ORDER NOW
EK Water Blocks EK-FB ASUS M6I - Acetal+Nickel (Original CSQ) @ £49.99 inc VAT
EK-FB ASUS M6I water block is a complete all-in-one (CPU and motherboard) liquid cooling solution for Intel LGA-1150 socket Haswell CPU and ASUS Maximus VI Impact motherboard.
This water block uses award winning EK-Supremacy cooling engine to ensure best possible CPU cooling. The water blocks directly cools Intel LGA-1150 socket type CPU, Intel Z87 Express southbridge (PCH) and power regulation (VRM / MOSFETs) module as water flows directly over all critical areas. It is a very high flow water block that can be easily used with systems using weaker water pumps.
Base of the waterblock is made of nickel electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber gaskets.
Water block is mounted with enclosed M2.5x4-, M3x6- and M4x10 DIN7985 screws and PVC washers and utilizes the factory provided MOSFET backplate. The nickel plated brass screw-in standoffs are pre-installed and allow for easy installation.
EK also encloses EK-LGA 115x TRUE Backplate to ensure even contact with the CPU as well as to prevent motherboard warping.
Enclosed thermal pad is used on voltage regulator modules to improve cooling performance of the waterblock. On the CPU and southbridge (PCH) chip please use the enclosed electrically non-conductive thermal grease EK-TIM Ectotherm.
Enclosed:
- water block
- EK-LGA 115x TRUE Backplate
- thermal pads
Fittings are not enclosed! Two fittings are needed for proper operation.
PLEASE NOTE:
ORDER NOW
EK Water Blocks EK-MosfetASUS M6G - Nickel (Original CSQ) @ £19.99 inc VAT
EK-MOSFET ASUS M6G is a water block for water cooling of the power regulation (VRM / MOSFETs) module on ASUS Maximus VI Gene- and Hero motherboard. It features a high flow design allowing the water block to be easily used with systems using weaker water pumps.
Base is made of finest electrolytic copper while the top is made of quality satin finish acrylic glass material. The sealing is ensured by the use of quality rubber gasket.
This product features preinstalled nickel-plated brass standoffs and utilizes ASUS factory provided backplates.
Enclosed:
- EK-MOSFET ASUS M6G series water block
- thermal pads
Only £19.99 inc VAT.
ORDER NOW
EK Water Blocks FB Kit for Gigabyte GA-787X-OC Motherboard - Acetal @ £39.95 inc VAT
EK-FB KIT GA Z87X-OC full-board water block kit is a complete liquid cooling solution for GIGABYTE GA-Z87X-OC motherboard. The water blocks directly cools southbridge (PCH) and power regulation (VRM / MOSFETs) module. It is a high flow water block kit that can be easily used with systems using weaker water pumps.
Specification:-
- Threads: G1/4"
Contents:
- 2x Water blocks (MOSFET & SB)
- thermal pads
ORDER NOW
EK Water Blocks EK-FB KIT EVGA X79 Classified CSQ - Acetal+Nickel @ £14.99 inc VAT
EK-FB KIT EVGA X79 Classified CSQ - Acetal + Nickel is a complete water cooling solution consisting of two separate water blocks for EVGA X79 Classified (E779) motherboard. The water blocks directly cools Intel X79 Express southbridge (PCH) chip and power regulation (VRM / MOSFETs) module. Please note this water block cools exactly as much heat generating components as EVGA factory cooling solution. This water block kit also features a high flow design therefore it can be easily used in liquid cooled systems using weaker water pumps.
Bases of the waterblocks are made of nickel plated electrolytic copper while the tops are made of quality POM Acetal material. The sealing is performed by quality rubber gaskets (NBR).
Enclosed thermal pad is used on voltage regulator module to improve cooling performance of the waterblock. On the southbridge please use any electrically non-conductive thermal grease, e.g. Gelid GC-Extreme.
A maximum diameter of a single barbs/fitting used on SB part of the water block kit is limited to 22.2mm in order to allow the installation of the graphics card mounted with EK-FC series backplate in the first PCIe x16 slot!
Enclosed:
- 2 x water blocks (MOSFET & SB)
- thermal pads
PLEASE NOTE:
- Fittings and thermal grease are not enclosed! Four fittings are needed to make this waterblock to operate properly.
Only £14.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FB KIT ASUS M6F - Nickel @ £29.99 inc VAT
EK-FB KIT ASUS M6F water block kit is a complete liquid cooling solution for ASUS Maximus VI Formula motherboard. The water blocks directly cools southbridge (PCH) and power regulation (VRM / MOSFETs) module and is designed to perfectly blends with the original design by utilizing ASUS original thermal armor plastic cover. It is a high flow water block kit that can be easily used with systems using weaker water pumps.
Base of the waterblock is made of nickel plated electrolytic copper while the top is made of quality acrylic glass material. The sealing is performed by quality rubber gaskets.
Water block is mounted with enclosed M3x4 DIN7985 screws and PVC washers. The 2.5mm nickel plated brass screw-in standoffs are already preinstalled and allow for easy installation.
Enclosed thermal pad is used on voltage regulator modules to improve cooling performance of the waterblock. On the southbridge (PCH) chip please use any electrically non-conductive thermal grease, e.g. Gelid GC-Extreme.
Enclosed:
- thermal pads
Fittings are not enclosed! Four fittings are needed for this waterblock to operate properly.
PLEASE NOTE:
ORDER NOW
**B Grade** XSPC Razor GTX Titan / 780 / 780Ti GPU Waterblock @ £29.99 inc VAT
Full Cover GTX Titan / 780 / 780Ti Water-Block with multiport connector.
- Dimensions: 266.7 x 124.4 x 25mm
- Prepared for SLI with 7 G1/4? ports
- Supports GTX Titan, 780 and 780Ti cards
(Nvidia reference designs only)
Originally sold at £79.16+VAT
ORDER NOW
**B Grade** XSPC AX360 Triple Fan Radiator (Black) @ £29.99 inc VAT
The AX is a new premium radiator from XSPC. The AX series combines a high performance copper/brass radiator core with a compact and beautifully finished aluminium enclosure.
The AX's core is a high performance evolution of the popular EX radiator series. The core includes advances from the EX series like welded seam tubes and splitter fins, but with a thicker core (21mm vs 16mm) and increased surface area.
The radiator core is fitted inside of a 3mm thick, extruded and machined aluminium shell. The screw holes are precision cut by CNC which eliminates misaligned screw holes and gives 3mm of screw thread. The aluminium shell also provides a perfectly flat surface to mount the fans against, which eliminates air gaps and any need for a gasket.
All of this comes together to make what we believe is the best PC radiator on the market.
- 3mm Thick Aluminium Frame (No aluminium in the flow path)
- Copper and Brass Core
- Matt Black Painted Core
- Black Chrome Plated G1/4" Ports
- RoHS Compliant
- Dimensions: 128 x 40 x 406mm (WxDxH) (46mm at ports)
- Weight: ~ 1082g
- Screws: 6-32 UNC
- Fans: 1 x 120mm (2x with push/pull)
Supplied 30mm and 6mm 6-32 UNC screws
Originally sold at £74.99+VAT
ORDER NOW
EK Water Blocks EK-FB ASR Z77 Extreme11 - Acetal+Nickel @ £14.99 inc VAT
EK-FB ASR Z77 Extreme11 water block is a complete liquid cooling solution for ASRock Z77 Extreme11 motherboard. This water blocks directly cools Intel Z77 southbridge (PCH), PLX PEX 8474 PCIe lane splitter, LSI SAS2308 control hub as well as power regulation (VRM / MOSFETs) module. It is a high flow water block that can be easily used with systems using weaker water pumps.
Enclosed:
- Water block
- Thermal pads
Specification:-
- Option: Nickel Acetal
- Threads: G1/4
ORDER NOW
Bitspower G 1/4" Silver Shiny Rotary 45 Degree 1/4" Barb Fiting - shiny silver @ £2.99 inc VAT
These new G 1/4" 45 degree angle fittings are perfect for tight spaces and change the direction of your water input or output without affecting flow. With 360 degree rotary fitting on one end you can secure the connection yet still twist the direction of the fitting to any angle you desire. No more kinked tubing! These are the bomb!
Features:
Real Hi-Flow Design.
Hi-Quality Copper Material.
45-Degree Fitting Angle.
360-Degree Rotray Angle.
Outstanding Outlook.
RoHS Ready
Specifications:
Product Name : G 1/4" Silver Shiny Rotary 45 Degree to 1/4" Barb Fitting
Model Name : BP-45R2III
Material : Hi-Quality Brass
Color : Silver
Only £2.99 inc VAT.
ORDER NOW
**B Grade** EK-FC Bridge TRIPLE Parallel CSQ Plexi @ £9.95 inc VAT
EK-FC Bridge TRIPLE Parallel CSQ is a high quality interconnect for connecting three (3) EK Full-Cover CSQ waterblocks in a single, sturdy unit. Connecting multiple graphics cards FC water blocks with akward fittings and tubing is a thing of a past!
For use with motherboards with PCIe x16 slots 40.6mm (1.6") apart!
Please note:
- The CSQ bridges are compatible with CSQ design full cover water blocks only!
- Despite putting every effort in machining, the surface of holes may include some micro scratches, which could not be removed. The occurance is less visible when using colored coolants of darker tone.
EK-FC Bridge TRIPLE Parallel CSQ Plexi is a high quality interconnect for connecting three (3) EK Full-Cover waterblocks in a single, sturdy unit. Connecting multiple graphics cards FC water blocks with akward fittings and tubing is a thing of a past!
Bridge is made of high quality satin finish plexi. There is no need to purchase additional links since the EK-FC Link comes with every Full Cover CSQ water block. Serial and parallel water flow are graphically explained in installation manual.
Included:
- 1x EK-FC Bridge TRIPLE Parallel CSQ Plexi
- 2x Plug G/14 - Nickel plated
- 1x mounting mechanism for connecting three EK-FC Links CSQ
Originally sold at £18.32+VAT
Only £9.95 inc VAT.
ORDER NOW
**B Grade** EK Water Blocks EK-FC970 GTX WF3 - Nickel - Fits Gigabyte Non-Reference GTX 970 @ £49.99 inc VAT
EK-FC970 GTX WF3 is a high performance full-cover water block for GIGABYTE non-reference design NVIDIA GeForce GTX 970 series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
EK-FC970 GTX WF3 water block features a central inlet split-flow cooling engine design for best possible cooling performance, which also works flawlessly with reversed water flow without adversely affecting the cooling performance. Moreover, such design offers great hydraulic perfromance allowing this product to be used in liquid cooling systems using weaker water pumps.
Base is made of nickel-plated electrolytic copper while the top is made of quality acrylic glass. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws and washers.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC970 GTX WF5 Backplate - Black or Nickel) which improves the looks of your graphics cards and also provide some passive cooling to the memory IC on the backside of the circuit board.
G1/4" threaded fittings can be used on both sides of the FC terminal. Up to four EK-FC970 GTX WF3 water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
Enclosed:
- EK-FC970 GTX WF3 water block
- thermal pads
PLEASE NOTE:
ORDER NOW
**B Grade** EK Water Blocks EK-FC R9-290(X) - Nickel Rev.2.0 @ £49.99 inc VAT
EK-FC R9-290X is a high performance full-cover water block for AMD reference design Radeon R9 290X and -290 graphics card. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC R9-290X water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps. The cooling engine now uses refined, 0.6mm wide microchannel structure to even further improve the heat transfer.
Base is made of nickel plated electrolytic copper while the top is made of quality acrylic glass material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC R9-290X Backplate - Black) which improves the looks of your graphics cards and also provide some passive cooling to the VRM section.
A reinforcing frame (EK-FC R9-290X Reinforcer - Black) is also available as an optional upgrade and is recommended for single-card configuration users.
Up to four EK-FC R9-290X water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
EK-FC R9-290X is also the choice of both PowerColor as well as VisionTek for their factory liquid cooled AMD Radeon R9 290(X) series graphics cards.
Enclosed:
- EK-FC R9-290X series water block
- thermal pads
PLEASE NOTE:
Rev.2.0 brings compatibility for previously unsupported MSI® and GIGABYTE® model graphics cards.
Originally sold at £73.29+VAT
ORDER NOW
EK Water Blocks EK-FC980 GTX Strix - Acetal+Nickel @ £89.99 inc VAT
EK-FC980 GTX Strix is a high performance full-cover water block for ASUS design GeForce GTX 980 Strix series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC980 GTX Strix water block features a central inlet split-flow cooling engine design for best possible cooling performance, which also works flawlessly with reversed water flow without adversely affecting the cooling performance. Moreover, such design offers great hydraulic perfromance allowing this product to be used in liquid cooling systems using weaker water pumps.
Base is made of nickel-plated electrolytic copper while the top is made of quality acrylic material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws and washers.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC980 GTX Strix Backplate - Black or Nickel) which improves the looks of your graphics cards and also provide some passive cooling to the circuit board VRM section.
G1/4" threaded fittings can be used on both sides of the FC terminal. Up to four EK-FC980 GTX Strix water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
Enclosed:
- EK-FC980 GTX Strix water block
- thermal pads
PLEASE NOTE:
Only £89.99 inc VAT.
ORDER NOW
**B Grade** EK Water Blocks EK-Coolstream RAD XTC 140 @ £24.95 inc VAT
EK Water Blocks has evolved within a few years into a leading provider of high quality watercooling components.
Technical details:
- Dimensions: 177 x 55 x 145 mm (WxHxD)
- Material: copper, brass
- Color: Black
- Weight: 0.95 kg
- Connectors: 2x G1 / 4 inches
- Fan compatibility: 1x 140 mm
- Fan / radiator mount: M3 thread (both sides)
Originally sold at £33.32+VAT
Only £24.95 inc VAT.
ORDER NOW
**B Grade** XSPC AX360 Triple Fan Radiator - White @ £54.95 inc VAT
The AX’s core is a high performance evolution of the popular EX radiator series. The core includes advances from the EX series like welded seam tubes and splitter fins, but with a thicker core (21mm vs 16mm) and increased surface area.
Specification:-
- Black Chrome Plated G1/4? Ports
- RoHS Compliant
- Weight: ~ 1082g
- Screws: 6-32 UNC
- Fans: 3 x 120mm (6x with push/pull)
- Supplied 30mm and 6mm 6-32 UNC screws
Only £54.95 inc VAT.
ORDER NOW
**B Grade** Koolance HX-CU1402V 30 FPI Copper Radiator - 280mm @ £20.00 inc VAT
HX-CU1402V is a low profile copper core radiator designed for two 140mm fans. With a fin density of 30 FPI (fins per inch), it offers best performance with higher air flow. It has a dual pass coolant design, and is G 1/4 BSPP threaded for hose fittings. 30mm (1.18") long mounting screws are included for 25mm thick fans.
Specifications:-
- Dimensions: 153 x 30 x 316 mm (W x H x D)
- Weight: about 726 g
- Material: Copper (Core), brass (tubes)
- Color: Black
- Compatible Fan: 2x 140 mm side
- Fin density: 30 FPI
- Thread: 2x G1 / 4 inches
- Scope of supply: 8 x 30 mm fan screws for two 25 mm thick fan
Originally sold at £52.49+VAT
Only £20.00 inc VAT.
ORDER NOW
[URL="http://overclockers.co.uk/showproduct.php?prodid=WC-512-EK"] EK Water Blocks EK-FB ASUS M6I - Acetal @ £49.99 inc VAT
Base of the waterblock is made of electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber gaskets.
Enclosed:
- water block
- thermal pads
PLEASE NOTE:
ORDER NOW
[/URL]
- Weight: 0.73kg
ORDER NOW
Specification:-
- Thread: G1/4
Contents:-
- Thermal pads
ORDER NOW
Materials:
- Terminal: Delrin
Scope of delivery:
ORDER NOW
Materials:
Base part: Copper
Terminal: Delrin
Scope of delivery:
Please note:
ORDER NOW
Materials:
Terminal: Delrin
Scope of delivery:
Please note:
ORDER NOW
Materials:
Base part: Copper
Terminal: Delrin
Scope of delivery:
Please note:
ORDER NOW
Enclosed:
- thermal pads
PLEASE NOTE:
ORDER NOW
Enclosed:
- thermal pads
Please note:
ORDER NOW
Enclosed:
- thermal pads
Please note:
ORDER NOW
Enclosed:
- water block
- thermal pads
PLEASE NOTE:
ORDER NOW
Enclosed:
- thermal pads
ORDER NOW
Specification:-
- Threads: G1/4"
Contents:
- thermal pads
ORDER NOW
Enclosed:
- thermal pads
PLEASE NOTE:
ORDER NOW
Enclosed:
- thermal pads
PLEASE NOTE:
ORDER NOW
ORDER NOW
- RoHS Compliant
- Weight: ~ 1082g
- Screws: 6-32 UNC
ORDER NOW
Enclosed:
- Water block
- Thermal pads
Specification:-
- Threads: G1/4
ORDER NOW
Features:
RoHS Ready
Specifications:
Color : Silver
Only £2.99 inc VAT.
ORDER NOW
Please note:
Included:
Only £9.95 inc VAT.
ORDER NOW
Enclosed:
- thermal pads
PLEASE NOTE:
ORDER NOW
Enclosed:
- thermal pads
PLEASE NOTE:
ORDER NOW
Enclosed:
- thermal pads
PLEASE NOTE:
ORDER NOW
Technical details:
- Color: Black
- Weight: 0.95 kg
ORDER NOW
Specification:-
- RoHS Compliant
- Weight: ~ 1082g
- Screws: 6-32 UNC
ORDER NOW
Specifications:-
- Color: Black
ORDER NOW
Enclosed:
- water block
- thermal pads
PLEASE NOTE:
ORDER NOW
[/URL]
