- 11 Dec 2005
- Cheshire
We have a lot of fantastic deals on clearence section watercooling. Fittings from 72p!
OcUK Value 1/2" barbed fitting G1/4 with O-Ring (Perfect Seal) @ £0.96 inc VAT
The perfect seal fittings ensure, as the name implies, a perfect seal with 1/2" hoses (approx. 13mm inner diameter). A hose clamp is usually not required, as the fitting has a large outer diameter.
Technical data:
Thread: G1/4
Compatible to hoses with an inner diameter of 13mm (=1/2")
Inner diameter of fitting: 1cm
Only £0.96 inc VAT.
ORDER NOW
Bitspower Adapter G1/4" to 11/8mm (BP-BSWP-C11J) @ £1.44 inc VAT
Only £1.44 inc VAT.
ORDER NOW
Bitspower Rotary Fitting "Q" - 360 Degree Water Cooling Accessory (BP-QR-C) @ £3.60 inc VAT
Bitspower now offers a chromed brass "Q" shiny fitting accessory to use for tight water-cooling situations. This is a Premium metal piece that is perfect for SLI on the bottom graphics card water block for bottom mounted PSU type cases and other tight spacings.
- Special Design for PC Water Cooling
- Perfect Surface treatment
- Real Hi-Flow
- Hiding O-Ring Design
- 360 degree Rotated
- Fit All Bitspower Compression Fittings
- Material : Hi Quality Brass
- Thread : G1/4"
- Inner G1/4" Thread No. : 3
- Chromed Brass 360 Degree Housing (Fittings Optional)
Only £3.60 inc VAT.
ORDER NOW
Koolance QDC (High Flow) Barb G1/4" To 3/8" - black nickel @ £0.72 inc VAT
Only £0.72 inc VAT.
ORDER NOW
Technical data:
Thread: G1/4
Only £0.96 inc VAT.
ORDER NOW
Only £1.44 inc VAT.
ORDER NOW
- Real Hi-Flow
- Thread : G1/4"
Only £3.60 inc VAT.
ORDER NOW
Only £0.72 inc VAT.
ORDER NOW
