Firstly apologies for the dreadful picture, graphics is not my strong point.
I am starting to accumulate the gear I am going to need so I thought I better start thinking about the layout
I am thinking the following
Dual Loop.
Loop 1 CPU 240 + 120 rad
Loop 2 GFX 240 rad
the first design I came up with is as follows. The rads can't change position as this is the physical limitation of the case. I am worried about the air flow though
I am going to be using Scythe GT 1850rpm fans on all rads and the front intake.
Main worry is that the push fans at the bottom are going to blast hot air up then the front intake wil blast towards the rear / top rads which are for the cpu resulting in not so great performance or is this not really that big a deal ?
I am mainly doing this becasue I like the challenge of getting this all into a CM690ii and of course I wouldn't mind attempting the hallowed 5ghz on my 2500K
Is there anything I should be doing better on this ?
The rad choices are made as based on my measure ups these will physically go where they are indicated on the diagram above
Dual Loop.
Loop 2 GFX 240 rad
