WaterCooling + CMStorm Sniper
20 Oct 2009
Hi All,
can anyone recommend what radiators+fan setups fit inside the sniper?
i've got an ga-x58a-ud7 board and have no idea what fits and what doesnt.
thanks,
k
Hi All,
thanks,
k
not 100% certain if this rad will fit with the fans, so check it first:
YOUR BASKET
1 x OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo £84.98
1 x EK Supreme HF CPU Waterblock - Nickel Plexi £56.99
1 x EK Dual Bay Spin Reservoir - Acetal £46.99
1 x XSPC EX240 120mm Radiator - Black £39.98
1 x Mayhems Pastel - Blueberry Blue Coolant 1L £14.99
2 x Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin £12.98 (£25.96)
1 x Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) Clear 3.3m £10.88
1 x OcUK Tube Cutter Aluminum 3-14mm £8.50
8 x OcUK 1/2" G1/4 - FatBoy Style - Black Nickel - Barb Fitting £1.68 (£13.44)
1 x OcUK Value PSU Bridging Connector (24 Pin) £1.30
Total : £316.02 (includes shipping : £10.00).
ok thanks.. i'll get a ruler out and start measuring.. am also wondering if i can mount the fans external in the cavity where the "handles" are.. and have them pull air up..
does this rad support that?
yeah.. i've actually being thinking about installing on the grilled side panel.. which fits a 200mm fan .... another alternative is to install it externally with a radbox or hollowed out 120mm fan
No, it's just that there may be a chance of the rad with a fan being too tuick and interfering with a graphics card or something else :)
so.. still thinking about this... and considering doing something like this ... with the help of a dremmel for the cut out on the top:
Front:
Phobya Xtreme 200mm Radiator
** Drive bays removed and 200x200 CoolerMaster fan mounted - pulling **
Top:
Black Ice Pro II Radiator
2 x Akasa Apache
** Radiator will either internal to case and fans mounted directly above externally, or vice versa **
Rear:
V12 Watercooling Kit 360 - or something similar with D5 pump and 360 rad.
