Hi, planning on upgrading to a opteron 170 setup, using a DFI nf4 expert, and also a 1900xt, probs be running g skill ZX ram too
First of all, will my Maze4 fit the 1900? - its around a year old.. maybe a bit less
(im thinking yes, as ive been told the 1900 has the same fittings as a 7800 - which im sure a maze4 fits)
Secondly: is there any point in cooling the northbridge? I'm gonna take the opteron as far as possible, ie 250+ HTT.. will the NB take this with just a stock cooler?
Finally, my current waterpump has developed a crack, so need a replacement, any suggestions? (the current one is a eheim 1250 - but its been pretty crappy.. so probs wont go with one again)
Btw, my current plan for the Watercooling setup will be:
Res -> pump -> cpu -> gpu -> rad -> res
Thanks in advance!
Thanks in advance!
Do I sniff a contradiction :\
