ive had my wc set up for a year now.
how long does the coolant last in the system im using feser one coolant
on a 240mm rad and cpu block and combined pump and res if it needs flushing how do i do it and what do i use?
also i got half a bottle left of the coolant from when i fitted the syatem last sept will it b ok to use thiat or should i buy new coolant?
thanks
thanks
