9 May 2006 at 18:56 #1 ted34 ted34 Associate Joined 5 Jul 2005 Posts 1,734 Location Edinburgh Whats better: dangerden tdx or alphacool nexxxos xp bold. Will be used with 1/2" hose but most important is has to work with ihs removed.
9 May 2006 at 19:03 #2 MikeTimbers MikeTimbers Soldato Joined 18 Oct 2002 Posts 8,309 Location Aranyaprathet, Thailand nexxxxxxxxos
9 May 2006 at 20:52 #3 ted34 ted34 Associate OP Joined 5 Jul 2005 Posts 1,734 Location Edinburgh Thanks will go with the nexxxos then. Is this def compatible when no ihs used?
30 May 2006 at 14:47 #4 Hesky82 Hesky82 Associate Joined 8 Jan 2005 Posts 2,405 Location Worcestershire ted did you get the NexXxoS XP block in the end?? lookin to go water on an ihs'less cpu to cheers
