14 Oct 2008 at 18:33 #1 Dark Sun Dark Sun Associate Joined 17 Sep 2008 Posts 815 Hi guys, Does anyone have any experience with the D-Tek 1/2" hose Barb? In the description it states "the oversized barb end can eliminate the need for hose clamps". Can I trust this? Should I use some hose clamps? Thanks! Last edited: 14 Oct 2008
14 Oct 2008 at 22:00 #2 fornowagain fornowagain Soldato Joined 3 Nov 2004 Posts 9,873 Location UK Use clamps or zip ties. Not worth the risk.
14 Oct 2008 at 22:19 #3 Bradley8988 Bradley8988 Associate Joined 19 Jan 2008 Posts 2,168 Location Sunny Wales. i use 7/16" tubing over 1/2" barbs and cable ties for good measure.
14 Oct 2008 at 22:47 #4 mike gunnz mike gunnz Soldato Joined 12 Oct 2007 Posts 2,647 Theres no way 7/16" hose is coming off a 1/2" DTek. I had to cut the hose off with a stanley knife the seal was so tight. They're excellent barbs.
14 Oct 2008 at 23:03 #5 Vertigo Vertigo Soldato Joined 28 Dec 2003 Posts 16,726 Use cable ties, although those barbs are one of the best you can buy and it's highly unlikely the hose would come off it without a cable tie.
