hey guys i wanted some extensive amounts of help regarding watercooling. i recently decided to go for WC setup for my i7 but unfortunately im completely clueless when it comes to selecting the right piece of equipment for it. i have been looking at components for around 5 months now at different websites but i always got confused with the dimensions required and how many of each piece of equipment i would need. anyways ill mention my pc specs first then ill ask the main question so here goes:
Intel Core i7 975 Extreme Processor
Rampage 2 Extreme Motherboard
12GB Corsair Dominator GT DDR3 2000MHz
Gainward 4870x2 DDR5 2GB GPU
Cooler Master Cosmos S casing
Now please keep this in mind that i only want CPU to be watercooled right now. NOT THE GPU!!!
think these are the components which should be related to WC setup, no need to mention the rest of the stuff installed. So what i request from you guys is to please lay out (in detail) as to what sort of equipment i should get for WC'ing. Like which block is the best (ive read quite good things about the swiftech cpu block), would a 240MM Radiator do the job or going for a 360MM is better? what are the pros and cons for both.
Go for drive bay reservoirs or tube ones? i also heard from a friend that drive bay reservoirs tend to leak (although i would prefer going for the drive bay one since it adds to the cool effect of the whole casing).
Which pump to go for? which are the better ones?
Now the real confusing part. How much tubing to purchase? Length wise and diameter wise (3/8mm or 1/4mm). the hose fittings, go for 3/8mm ones or 1/4mm ones?...whats the difference between both? and how many hose fittings would i need?
please if some one can list down everything for me it would be a great help. thanks a lot
and sorry for the noobism
. yes i have been oc'ing the 940. managed to take it upto 4.2 on air. wouldnt boot at any frequency above that. my main reason for oc'ing is just running the benchies and competing with the guys on another forum.
