Watercooling/Fan Placement
4 Jun 2015
Hey guys,
First thread!
Right I've been looking through this forum for advice on water cooling and found a lot of really helpful advice so thanks for that! I've got some water cooling on the way and 2 extra fans,
I've got a rough idea in my mind of how I'm going to set it up, but I am a first-time noob with water cooling and Intake/Exhaust methods.
I'd like to get some general opinions on what I should do with the equipment I've bought
This is the case I own:
http://www.amazon.co.uk/gp/product/B000O8JD92?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
Note: It has a dual fan slot at the top, 1 fan slot at the back, front and side.
I've bought this water cooling:
http://raijintek.com/en/products_detail.php?ProductID=18
and these two fans:
http://www.amazon.co.uk/gp/product/B00F6S13DE?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
My graphics card is a 290 tri fan pointing downwards at the case offering another 3 fans to the mix.
What I thought id do is:
Have the dual fan water cooling in the top fan slots (only place it will fit) as a Exhaust, helping the overall temperature of the case cool down.
Have 1 of the Fan's in the front of the case in-taking cool-ish air
Have the other fan as a "exhaust" on the side of the case pulling away some of the heat the graphics card throws out
Is there a way I could improve this? Not looking for a 100% guide or anything just some advice from fellow more experienced air flow users :p:p
For my loop I pull air into the case via 2*SP 120 front fans on a RAD and pull air out the top via 2*SP 120 fans on a RAD.
So you have put forward a sensible setup. Those Corsair fans are AF, so they should be put where there is little restriction such as font and back case mesh. The fans on your sudo AIO should be SP as they have to pull the air through the RAD.
Sorry gunna be a rookie here, Does SP refer to Exhausting?
SP is Static Pressure and that means fans in this class are designed to move air when they encounter resistance, i.e. a RAD in front of them. The air flow is focused.
AF is Air Flow and is the more traditional fan design, where fans in this class are designed to move air all around, they are not expecting anything in the way which produces resistance (IE. a RAD) so the air flow is more diffused. This is why you see them as exhaust fans at the back/top or pulling air in the front of the case through case mesh or a filter.
Peoples experiences tend to show that the general rule is to pull in the front/bottom and exhaust back/top.
Okay so by that logic my idea of having then side fan, I should move that side fan to the rear slot instead? that way i have a air flow output At the back and top instead of top and side?
Yes, go with that. You can always add extra fans to the side later if you thinks the temps on the 290 are not great. your going to be exhausting in two places, so that might be all you need.
Yeah the 290 can crank up some real heat when playing GTA 5 which for obvious reasons is a heatwave game in itself.
The game makes all my equipment bump up a extra 10-15 degree's more than any other game and I own a fair share of games
Really into GTA at the moment so would like to not set my house on fire whilst playing :)
