hi,
iv built a few watercooling setups in the past but nothing this complex, my issue seems to lie with fluid dynamics which i cant seems to get my head around this time
im using the d888wx
my loop order
bay rez koolance rp-542x2 inc pumps
over the the other side into gpu 1
into top rad
into gpu 2
into front rad (top ports)
into bottom rad
then into a t-peice with a valve that i can lower out of the case a small amount
into cpu
over to the other side into top rad
then into a T-peice with another value for drainage
back in the rez
the idea being the left have main drain would drain everything down that side, then use the right drain to empty out the rez and anything left in the top right rad
however it seems to really not be happy about drainage or filling (fill in rez)
when trying to fill it really struggles to get the air out to the point where i cant even get the water into the pumps, this includes when im resting the rez out of the case on top (usual way i fill is to place it at the highest point)
right hand drain is fine, only lets out a small amount as expect, the left hand drain again does some but not as much as expect, it takes around 2.5 litres to fill but drains (caps off rez tilting but not removing rads etc) under a litre.
annoyingly the first fill i did was with blitz part 2 and it filled up fine good amount went in before needing to fire the pumps up, since then i just wont drain down very much to allow for a good flush through let alone putting in premix
iv tried to change the design abit and tubing slightly with no luck, not that any water came out while doing it, i should add that once it running and finally managed to get the air out its great, but that initial fill and drain is the issue.
i would like to do a bottom fill, however that also failed im guessing due to trapped air in a rad and the water just goes the other route and does not vent out the rez
any suggestions?
im using the d888wx
my loop order
into top rad
into gpu 2
into bottom rad
into cpu
back in the rez
any suggestions?
