watercooling flow seems weak is this normal ?
29 Dec 2012
My watercooling flow seems weak from the cpu block to the rad and from the rad to the res, is this normal ?
the flow from the res to the pump and pump to the cpu block is good
Did you bleed it? Gave the case a good shake etc, you would have noticed a lot of bubbles moving up the res. Are your temps ok? Temps being fine is a good indication that everything is ok.
Quick question:
How do you know what is the flow rate in parts of your loop?
By definition, flow rate within a continuous loop must be uniform unless you have different ID tubes within the same loop.
Quick question:
the tubing is the same the only difference I can tell the tubing connected to the pump is full and you can feel it moving, the part connected to the rad seams empty and you cant feel it.
Can you take a picture and upload it so that I can see what you mean?
the ones with the blue line are the ones, I cant tell if they have any water
Ok.
So you cannot fill the vibration on the tube compared to that connected to your pump?
In that case, I would not worry about it.
1. The reason why you can "feel" the water in the tube connected to the pump is probably because the hydraulic pressure in that particular length of tube is high, and giving you the "weight" of water within. But when the fluid travels through various components the pressure drops and you will no longer feel the vibration or the "weight" of the fluid within.
2. If there is no leak within the system, that means the fluid is still within your loop, so there is nothing to worry about :)
Hope this helps.
Yes it helps, I can not find any leaks, Im getting good temps, I hope theres no leaks.
I just wanted to know if it was normal.
