It makes no difference, what ever simplifies the tube route is what you should go for, whether that places the blocks before or after the radiator is irrelevant.
Precisely. Poor flow makes more of a difference than what order the parts go. So whether the rad is before the cpu or the cpu before the gpu is less important than that the piping is as short and straight as possible. Sharp bends will affect the overall performance more than the sequence.
the only connection order that really matters is with blocks that have "direction"
eg all the high resistance jet design blocks *need* water going in thru 1 barb out out the other(others) and for all blocks with a center barb, over the core waer should go in over the core.
