Watercooling fluid
27 Mar 2016
Bristolian living in Swindon
Hi all
So I'm going to be watercooling my pc some point over the next month, just getting the last few bits... I haven't ordered fluid yet but I've been checking a few out...
Do coloured fluids need mixing with distilled water or can they go straight in the loop?
Do they tend to clog up compared to clear fluid?
Do I need to flush my radiator before fitting in the case? Its a brand new radiator from OCUK
Cheers
Just get a pre mix like Mayhems X1 fluid or pastel range. Yes you will need to flush the rad out with distilled water, I do it warm and do a few rinses until its clear coming out in a dish.
Brilliant thanks i'll have a look at the Mayhems, Where is the best place to get distilled water?
I just flush mine with the water from my
Condenser dryer
Lot of people will say you need to do it
With mayhem blitz or similar
But never had any problems
You can buy your coolant premixed in 1l bottles
Or in concentrate to add to distilled/deionised water
Condenser dryer
Cheers bud, Do coloured fluids cause any issues in loops or do they need maintaining more than clear fluids?
i used to use pre mix .. until it ate away a gpu block and then another that clogged a cpu block .. now i just use distilled water and silver coils .. if you want colour go for coloured tubing ..
Yeah that's the worry I have... Think I will go clear tbh
Never had a block eaten away
In over 10 years
That sounds more like galvanic corrosion
Than caused by coolant
I have to agree with this in all my years of watcooling
Ive never had a problem with mayhem pastel and used it for years and in multiple computers I've used red blue and green and never had any damage to any block cpu or gpu
I only use clear, XT1 nuke concentrate mixed with distilled, not de-ionised, water.
Don't like coloured fluids, they stain, they sometimes gunk, and I like the look of clear in the Res.
Some mixed opinions here.. No matter what I go for are the Premixed bottles ready to pour in? I'm guessing that's why they're called Premixed :p
Whats PH balance? :p sorry new to all this
Basically if the fluid and components have a PH inbalance it's more likely to react and corrode/separate and give you headaches. Mayhems did a video cleaning the radiators with their Blitz kit they sell and explaining why it was done and gave a break down as to the implications of what might happen if you didn't do it. It basically does a deep clean on the system and radiators in particular which should give you a PH balanced system that your fluid can go into and therefore reduce any likely issues down the line.
