watercooling for cpu
12 Dec 2012
essex
right im just looking at getting into the water cooling scene for my rig
what will be the best to go for under £250
im useing a am3+ AMD FX-8150 cpu
but would like some one who knows about water cooling to check :)
i would say if you don't mind moding the case a 240 rad in the bottom and a 240 rad on the top.
I run a single 360 Rad cooling my 8320 and gtx670 ftw.
If you don't want to mod a 240 in the top and 120 at the back
What passey89 linked you to will worked great for just a cpu although I'd buy some Scythe Gentle Typhoon 120mm 1850 RPM. Although they say 28 db you really can't hear them, and I'm the really fussy type so was surprised at how quiet they are and the amount of air the push through a rad, People always go on about Noctua fans being quiet but I'd say these are much quieter. The kit you linked to first op wouldn't fit in that case as it'll only fit a 240mm rad.
thanks guy i have been looking at a number of kits and im putting it off to the new year as going to order my new video card at the same time
