watercooling for GPU Help and Advice Needed.
hi my temps when playing crysis have been hitting 100c -102c which is far too hot for a 8800 GTX and eventually will kill my card im sure. i have a decent coolermaster case with one fan at the back and a fan at the top with a small system cooler fan underneath the GTX. still not happy with my temps though.at the moment idle is 63c which is ok i suppose but when i play games it rockets to 85-100c so ive been thinking about watercooling the GTX are there any good cheapish water cooling kits on overclockers that are recommened? i dont wont to be paying £100 plus mind you. or will the Thermalright HR-03-PLUS be good enough and do i need to buy a fan to go with this?.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-038-TR&groupid=701&catid=57&subcat=787
so it'd be best of you posted some pictures of the inside of your case.
