Hey guys. My current system is an i7 3770k and SLI 670s. The 670s are reference designs and they howl once the temperatures start rising. I've looked in to other ways of reducing the noise from them, but aftermarket air cooling like an Xccelero won't fit with my current config and sound card - so naturally I'm considering just going for full water since it's always been something I've wanted to do.
Below is what I've specced up, mostly as a 'money no object' spec. You'll notice it includes a new case because my current case (NZXT Hades) is awfully designed and cannot fit a decent amount of rad space anyway (probably 120mm + 240mm external, at a push).
There's also a t-piece and related fittings for installing a drain port at the bottom of the case.
YOUR BASKET
1 x Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) £134.99
2 x EK Water Blocks EK-FC670 GTX CSQ £69.98 (£139.96)
1 x XSPC D5 Vario (Body + Screwring) £56.99
1 x EK Water Blocks EK-Supremacy £51.95
1 x XSPC EX360 120mm Radiator - Black £49.99
1 x XSPC EX240 120mm Radiator - Black £41.99
1 x XSPC Acrylic Tank Reservoir for Laing D5 £28.98
2 x Monsoon 16/11mm (ID 7/16 OD 5/8) Free Center Compression Fitting Six Pack - Blue £27.95 (£55.90)
1 x Akasa 5.25" FC Six Channel Brushed Aluminium Fan Controller [AK-FC-08BKV2] £24.98
1 x EK-FC Bridge DUAL Serial 3-Slot CSQ Plexi £18.98
1 x Mayhems Pastel - Blueberry Blue Coolant 1L £14.99
5 x Noiseblocker NB-eLoop Fan B12-3 - 120mm £13.99 (£69.95)
1 x Aqua Computer Ball Valve Female Thread G 1/4 without Fittings £5.99
2 x Primochill Primoflex Advanced Tubing 16/11 - Black £5.99 (£11.98)
1 x XSPC G1/4" T Fitting (Black Chrome) £3.95
1 x OcUK Fillport Black Nickel - Knurled - Universal £2.99
2 x XSPC G1/4" 10mm Male to Male Fitting (Black Chrome) £1.79 (£3.58)
1 x XSPC G1/4" Plug (Black Chrome) £1.55
Total : £736.19 (includes shipping : £13.75).
For starters, are there any glaring issues with the proposed loop?
Now this is where it gets a little more complicated: I'm expecting to get zero performance increase from the improved cooling. None of my hardware are particularly good overclockers, and appear to be at their limit (and limit of my overclocking skill) on air - 3770k @ 4.4GHz / 1.3v, 670 @ +59 / +400 / 1150mV. Thermals aren't an issue, as said before it's just loud.
Given that I don't need supreme overclocker-levels of cooling, is there anything in the loop you'd change to save money?
Final question: would it be a better use of the cash to just wait and buy a pair of 770s or similar with nice third-party coolers? Hell, ~£750 is close enough to 2x7990s.
Thanks for any advice you can give!
YOUR BASKET
