I am contemplating watercooling my system (spec below). However want to get the R600 when it comes out. Plus generally have a quieter pc because atm is quite loud to some extent. Since I also use my pc as a media centre (connected to a 40" LCD) would be good to get it quieter.
Been looking at water cooling and love the look of the Zalman Reserator 2 but doesn't look great at actual performance figures. Now is it possible to add the Swiftech MCR320-QP Triple 120mm Radiator or the Thermochill PA120.3 120mm Triple Radiator to give it improved performance whilst also keeping it quieter than air cooled?
Would I need a second pump? Or will stock do fine? If stock pump isnt fine anyway to change the stock pump for a more powerful one?
But might upgrade case when I get a R600, as will be a tight fit and may require mods.
