Hi all,
I have a Tai Chi case with the watercooling system that came installed. I am putting an Abit IN9 32x Mobo, 4x Gb Corsair Dominator 8500, XFX 8800GTX, QX6700, into the case.
I have also got the Danger Den 8800GTX block and a DDen Black Ice GTX240 Rad, FluidXP+ Extreme, and Tygon 1/2"ID tubing to go into this setup. Currently the 1/4" tubing goes from the Rad in the case to the GPU and back, to add the setup above to this case what is the best way? i really want to remove the 1/4" easy connectors on the cpu block and the thermaltake rad and change them to 1/2" connectors that way i can use 1/2" tubing all round. Thermaltake are just crap at answering questions, i found the 1/2" connectors on their website but need somewhere in Ireland to get them.
I was going to run the current rad to the cpu and then to the new danger den rad then to the gpu and return to the first rad. The case already has holes etc to expand the current water system and i was going to mount the rad just behind the case.
Does anyone know where i can get the 1/2" connector to change the 1/4" ones on the cpu block.
