Your basket
Product Name Qty Price Line Total
Alphacool NexXxos Xtreme II Rev2 Double Radiator £24.99
(£29.36) £24.99
(£29.36)
XSPC Tubing Clip For 1/2" Hose £0.49
(£0.58) £3.92
(£4.64)
Swiftech MCRES-Micro Watercooling Resevoir £9.99
(£11.74) £9.99
(£11.74)
Feser One UV Reactive Coolant 1 Litre (Black/Blue) £6.99
DON'T NEED THIS - JUST USE DISTILLED WATER. OR EVENT TAP WATER IF YOU DO IT PROPERLY!
(£8.21) £6.99
(£8.21)
Masterkleer 7/16" Tubing - 1m £1.49
(£1.75) £4.47
(£5.25)
EK 1/2" Hose fitting £1.99
(£2.34) £7.96
(£9.36)
Laing DDC 1-T Pro 10W 12 VDC Pump £39.99
(£46.99) £39.99
(£46.99)
D-Tek Fuzion Universal VGA Block (ATI X2900XT, Nvidia 6800/7800/7900/8800 series) £24.99
(£29.36) £24.99
(£29.36)
D-Tek Fuzion V2 Universal CPU Block (AMD Socket A/754/939/AM2, Intel 478/LGA775/423/771/603/604) £34.99
Swiftech APOGEE GT (if it has to be from here) WILL DO THE JOB JUST FINE - NO POINT GOING FOR TOP PERFORMING WATER-BLOCK WITHOUT A THERMOCHILL, etc.
(£41.11) £34.99
(£41.11)
Akasa AK-TC TIM Clean CPU & Heatsink Cleaner £3.99
JUST USE NAIL-POLISH REMOVER, BUT BE CAREFUL NOT TO GET IT ON ANY PLASTIC.
(£4.69) £3.99
(£4.69)
Arctic Cooling MX-2 Thermal Compound £3.99
(£4.69) £3.99
(£4.69)
Sub Total : £166.27
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.95
VAT is being charged at 17.5% VAT : £30.66
Total : £205.88
You will need same ram heatsinks for your GT memory as well.
Probably not, tbh. Especially if he's going budget.
I have selected the d-tek fuzion cpu block because it will fit lots of systems if you upgrade later especially to an Intel quad core.
You can knock of the Feser if you want and go with Mr Thingy's suggestion.
Good man.
If you don't want to cool the GT you can knock off £30.51 from the price getting you to £175.37
Of course you might have TIM cleaner and decent thermal compound already.
