OK my systems finally all up and running, no leaks (thank god). However there are loads of tiny air bubbles in the loop. They are stationary not moving? Also the flow meter on my reservoir (EK Spin) is completely stationary, but you can see the waterfall on the front so it must be flowing?
How can you tell if the water is moving or not? Also are the small stationary bubbles normal?
I've been running the loop with the res top off for 4 hours or so and the bubbles just wont shift, I've tried tilting the case and even shaking it a bit.
I havn't powered the system yet, just the loop as I'm worried if the flow is crap it could damage it?
FYI It's a CPU/GPU loop with one D5 pump and 2 rads (1 x 120 & 1 x 360), with feser one coolant.
