- 21 Apr 2010
Hi, i am new to watercooling and need some help. I have a Antec 1200 case, i7 920 CPU, Asus Rampage II Extreme motherboard, Nvidia 295GTX graphics card. I want to cool everything (CPU, GPU and motherboard chipset). I am thinking of putting 2X XSPC RS240 120mm Rads as i understand one will fit very well in the back of the case where the fans are. I would use the Antec 200mm rad in th top of the case too but i understand they are aluminum and it dosn't mix well with copper.
I need help with what parts to use and any other sujestions (fluid, everything), the best blocks to use and what size pump and resevoir (is it best to buy these as seperate or all in one)........HELP....... no budget just want good parts that will last.
