Watercooling help
9 May 2007
Hi im kind of new to water cooling but i want to give it a go it will be in a corsair 800d case.
I was wondering is this a good starter kit http://www.overclockers.co.uk/showproduct.php?prodid=BG-010-XS&groupid=962&catid=667
and if all the fitting are good and wont leak on me and if i can upgrade it in the future
The specs of my pc is
i5 3570k
his 7950 iceq
16gb samsung green ram
All the fans will be the corsair sp120
If its missing anything please let me know
the block is good, the radiator is good, the rez isnt too bad, but if you are cooling more than your processor/gfx card, id probably go for something a bit better.
the barb and clips are something ive not used (i use compression fittings) so i cant comment on them, but i know people who do use them and they have been fine.
