im soon buying a 750d case for my upcoming build however i have no idea where to mount my alphacool xt45, im not sure if there will be sufficient air flow if i mount it in the front due to the flat front case design. as well as the radiator im also not sure how the tube reservoirs. im a first time watercooler and i will only be watercooling my cpu. Also can anyone spec a pump and tube reservoir i should get.
