Watercooling I9-13900KS
18 Oct 2022
Italy
Hi guys,
I own a pc with a an I9-13900KS.
I have a Corsair watercooling with a 360mm radiator but I go always i thermal throttling.
Can you hel solving the problem suggesting me a good cooling solution?
Thanks!!
A little more info would be useful, we're not magic here!
What case, are you maxing out the fans, what rad are you running, have you checked flowrate etc etc.
Have you tried any troubleshooting steps yourself so far?
When you say thermal throttling, how far are the clocks going down?
What load does it take to get the cpu to throttle, is it doing it at idle?
Have you tried re-mounting it?
I9-13900KS.
you need to under volt the CPU, nothing can cool it when it left to its own devices.
set a voltage off set in bios and you will unlock some performance but it will still run hot that's just the way this CPU is.
ALSO
cheack the pump is working, and set to 100%
delid it and direct die cool it with a custom loop, or if u cant be bothered sell it and buy a 7800X3D and cool it with whatever 20 euro cooler
how does the 7800x3d have the same issue if it pulls half the power?
Heat is the problem not power(yes power make heat)... both chips use power in different ways so both run hot.. and need to be undervolted / Curv Optimised to really stretch there legs.
Yes the AMD as less of a problem but its not just a plug and play option.
my little 5800x gams at 91c with custom water as default setting. and thats only 105w
I run the same cpu with a artic freezer 2 420mm aio I've also installed a thermaltake contact frame, the main problem I found with this cpu is at stock setting it gets a stupid amount of core volt so I decided to sort it, I'm running the p cores at 5.5ghz e cores at 4.2ghz with 1.24v with idle temps at around 24c and gaming temps 38c odd.
Same here aio artic freezer 420 and p1 150w p2 253w max voltage limits applied as per Intel specs
