Watercooling in 900D
12 Jun 2015
Hi,
just wanted to know if anyone could help me with a Corsair 900D case with watercooling please?.
I am looking @ purchasing the case but wanted to know a few things
1) can 2 x 480mm rads be mounted next to each other on the bottom side by side?
2) can the 5 1/4" drive bays be removed to fit a rad bigger than the 360mm specified it can accommodate?
3)can all ards be 60mm thick that are mounted into it?
really appreciate someones input
regards & thanks
1) no. As the PSU fits on one side. Unless you put the PSU in the roof or something. You can though fit a 480 on the side where the window is and 240 in the back. Then a 480 in the roof. Thats how I have mine.
2) yes they can be removed, I have my SSD mounted to a plate and hard drive in the back also mounted on a plate. But you would only be able to fit a 240 due to the radiators being in the way in the bottom of the case.
3) Id be tempted to say no because they will be quite tight. I have 2x 38mm on the bottom. the 480 is about 3 inches from the PSU.
Hi Tyler,
out of interest what is the measurement on the internal width of the case please? just wondering if I could get away with fitting a 480 & maybe a 360 back to back or even a 480 & 240 back to back with the 240 on the other side of the bottom?
Thanks for clearing that up for me gratefully appreciated. ;)
