** WATERCOOLING IN SMALL SPACES JUST GOT INTERESTING **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
In stock and ready to ship, we have the fantastic Alphacool DC-LT Ceramic 12V Pumps
The small footprint of these units make them ideal for watercooling in small spaces.
You need to add a Alphacool DC-LT Plexi Top to allow the pump to be mountable and to allow fittings to be used with the pump.
We also stock the Alphacool Reservoir for DC-LT pumps that fits directly to the Plexi Top. This gives you the option of incorporating a reservoir into the pump setup. the whole thing is tiny and realistically is the smallest Res/Pump solution on the market.
we have taken a picture with it next to a pound coin to give you a sense of scale.
Alphacool DC-LT Ceramic - 12V DC - Pump @ £19.99 inc VAT
Alphacool DC-LT ceramic 12 Volt pump, the compact pump with lots of steam under the hood!
Water cooling generally is not only for Big towers and the high-end sector. Barebones, HTPC and Desktop systems also greatly profit greatly from a liquid cooling system. Here extreme overclocking is not the goal, but rather total silence in the system.
Besides the fans, which are extremely quiet to silent thanks to the water cooling system, the pumps are another noise emitting element. Not with this pump! From the start much quieter than the majority of the competition and still powerful enough to cool CPU and GPU with ease. A ceramic shaft promises a long lifespan and permanently smooth operation.And the size? The outer dimensions are roughly the same as of a 2 Euro coin (about 5mm larger in radius).
This is the currently most compact water cooling pump for computer cooling!
Technical specifications:
Dimensions (WxHxD): 51x48x9mm (without fittings)
Standard voltage: 12V DC
Power draw: 1.4-2W
Permitted voltage: 12V DC
Pressure head at 12V: 2.5m H2O
Maximum flow rate: approx. 350l/h
Pumped medium: Water, Water/glycol mixture
Maximum system temperature: 65°C
Power connector: 3-Pin fan plug
Weight: 41g
Extent of delivery:
1x Alphacool DC-LT ceramic 12 Volt pump – bulk
Please note: This pump in its bulk version has no connection threads. We recommend ordering the suitable top from our portfolio with this pump.
Only £19.99 inc VAT.
ORDER NOW
Alphacool DC-LT Plexi Top @ £14.99 inc VAT
This is the ideal top for the Alphacool DC-LT pump.
This top is designed in such a way to allow mounting on the Alphacool DC-LT pump. With the top it is possible to integrate this miniature pump into your water cooling loop via ¼” threads.
The inlet fitting can be connected on the side or on top of the unit. The outlet is then connected to the opposite side.
All silent system enthusiasts will be happy to hear that threads were implemented to allow decoupling with e.g. Item No. 13701. With these decouplers the pump and top can be mounted in a 3.5” drive bay.
Thought was also given to the case modders amongst us, a 5mm LED hole near the outlet allows unique lighting effects for your system.
Dimensions (LxWxH): 49x49x24mm (without fittings, without pump)
Weight: 66g
Material: Röhm Plexiglas GS
Mounting: 4x M4 threads
Connection threads: 3x ¼”
Extent of delivery:
1x Alphacool top DC-LT Plexi
Mounting screws for the DC-LP pump
Note: For operation of the top only one of the two inlet openings is needed. We recommend ordering a screw plug with this top.
Only £14.99 inc VAT.
ORDER NOW
Alphacool Reservoir for DC-LT pumps @ £14.99 inc VAT
The ideal addition to the Alphacool DC-LT ceramic 12 Volt pump equipped with a Alphacool DC-LT Plexi top.
The Alphacool reservoir individual for DC-LT pump is another module for expansion and improvement of the Alphacool DC-LT ceramic 12 Volt pump. As basis a pump already equipped with an Alphacool DC-LT Plexi top is used. With only few steps this pump can now be additionally equipped with a reservoir. Simply place the reservoir on the included ring gasket and tighten the four also included screws in the corners: Done!
¼” threads are machined into the side of the reservoir. They can be used as an Inlet or for a lighting module.
Material: Röhm Plexiglas GS / brass
Color: Transparent / black
Dimensions (LxWxH): 49x49x56mm (without fittings, without pump)
Weight: 141g
Connection threads: 1x ¼”
Fill level indicator thread: 1”
Extent of delivery:
1x Alphacool reservoir individual for DC-LT pumps
1x Gasket
1x Fill level indicator with gasket
4 mounting screws
Please note: For operation of the top only one of the inlet openings is needed. Hence we recommend ordering a screw plug.
ORDER NOW
also
we have these too :)
OcUK Tech Lab - Alphacool DC-LT Ceramic 12V Pump, Top & Reservoir Value Combo @ £48.98 inc VAT
Assembled in house by Expert OcUK Technicians
The DC-LT is the most reliable Small Form Factor watercooling pump design.
The specially selected Alphacool Plexi Top improves the performance of the already impressive DC-LT pump further.
This aftermarket pump top improves performance by increasing the head pressure created by the pump. This means strong consistant flow around your loop and no slow points or hot spots.
The Plexi Top and Reservoir Combo also gives the user several configuration options by adding the ability to use standard sized watercooling fittings as well as controlling tubing layout
Easy filling through the reservoir top is one of the many great features of this excellent combination.
Every OcUK Tech Lab - Alphacool DC-LT Ceramic 12V Pump, Top & Reservoir Value Combo is assembled by an Expert OcUK technician and tested for quality assurance before it ships to the customer.
Power draw: 1.4-2W
Weight: 41g
Only £48.98 inc VAT.
ORDER NOW
Might want to add a stop fitting to the tech lab combo - or the second inlet will leak all over the noobs pc :)
Any chance of a top/pump combo price - like the alpacool site ;)
Well, just placed an order for this and the ozone ground level. Should be better (hopefully quieter!) than the XSPC 750 pump :)
