Hi Guys,
I have just added a water cooling system to my machine and am having problems.
Briefly, I am cooling an Intel i7 920 at 4Ghz (previously using a Corsair H50) and 2 x Nvidia GTX 580.
So the water cooling I have added are as follows
Swiftech MCP655 variable pump - currently set to 4...maybe it needs to go to 11
XSPC Dual-bay reservoir
Black Ice Stealth 360 Gen 2 triple-fan radiator
Swiftech Apogee CPU block
2 x EK GTX580 waterblocks
This is all wedged into a Coolermaster HAF-X case.
I noticed that ArmA2 was causing GPU1 to run upto 3 degrees higher than when using the card's stick cooling (stock upto 90 degrees, last night got to 93 before I decided to shutdown).
Flow is as follows: Reservoir to radiator to CPU to GPU1 to GPU2 back to reservoir.
I think I may have isolated one problem...
I have 3 Gelid Silent Series 120mm fans mounted below the radiator blowing out the top of the case (I, erm, liberated them from work to save a few pennies), but am now thinking they are not man enough for the job, as they are only rated at 37 CFM airflow. I have ordered 3 x Akasa Viper FN059 (up to 83 CFM) to replace them.
Can you think of anything else I should look in to as I'm not 100% convinced these will necessarily solve this? I'm concerned I have underestimated the requirements to water cool this?
Was running with just 12v to the pump to test it for >12 hours, and had the PC on all angles/sides and detected no leaks or anything dire like that.
Moochos grassyarse in advance!
