Watercooling Kit advice
22 Mar 2005
Maidenhead, England
Hey I need some advice with watercooling kit, I'm going to be w/c my my E6300/Q6600 rig before i32 along with the 8800GTS and the motherboard hopefully. I used to have the termaltake bigwater 775 set when I had my TT armour but it took up too much space and was only 3/8" kit, I want to move onto 1/2" stuff as I now have an Akasa Eclipse, I just have no idea what kit to get apart from being recommended the Black Ice Stealth 240 rad.
Well, conventional wisdom says go for the following, and assuming budget isn't an issue:-
Double or triple thermochill radiator, with Yate Loon or Sharkoon Silent Eagle fans
DDC Ultra pump
D-Tek fusion or Apogee GTX CPU block
EK 8800GTS GPU full cover block
Swiftech MCW30 for N/Bridge
Res of your choice or T-Line for bleeding
But, your black ice rad and a cheaper pump/res will do the job too, just not as well, but we're only talking a few degrees here.
There are many many posts on this subject though, if you want to have a search about.
