- 31 Jul 2010
- Stoke-on-Trent
Hi Guys,
I am looking to watercool my system and im wondering if you think this setup would be any good and would it keep things cool.
Kit to be WC'd is:
i7 2600k overclocked to 4.5ghz
2x SLI GTX580's will be overclocked to around 920mhz
Ideally i'd like to have a single loop if possible more than a dual loop due to space. (if this is not possible to get good temps then it will have to be dual)
I was looking at the following kit, basically will this be enough to get good performance with the above CPU and GPU's being overclocked.
EK Supreme HF CPU Waterblock - Nickel Plexi
EK GTX 580 Full Cover Waterblock - Nickel Plexi x2
Hardware Labs Black ICE SR-1 360 Radiator
Hardware Labs Black ICE SR-1 240 Radiator
Laing D5 Vario Pump -T12 12V DC Pump
XSPC Single Bay Reservoir
Masterkleer Tubing PVC 1/2" ID
Scythe Gentle Typhoon 1850rpm fans
I've not put down all the little bits like barbs etc.. but thats the kit i was looking at.
Do you think that will cool a i7 2600k overclocked 4.5ghz and 2x GTX 580's overclocked to 920hz on a single loop?
Thank in advance guys.
Dave
Kit to be WC'd is:
Dave
. I was asking what reservoir and pump would you recommend, or were thinking of in your post.
