Watercooling kit config
30 Jan 2012
I've only ever really only used air coolers and aios and now that I've invested a large sum of money into my new rigg, the next step is to buy a full hardline loop for my CPU and GPU. Ive seen that ocuk have a kit config but I really don't know where to start, ive watched a few videos in the past on building and I guess my budget would be around 400 to 500 max without the GPU block.
Any help or info on what I should be looking at would be great.
Basic would be ;
Obviously the block needs to be AMD or Intel depending on your cpu.
Radiator - largely depends on your case and whether you can fit multiple radiators if needed
Fittings - 2 per components in your loop ( pump / rad / cpu block=6 , or 8 if you want the gpu block )
Tubing - order more than you thing you'll need, i've doubled up in the picture. Unless you are a genius, you will make mistakes first time hardline bending.
Then there are things link a heatgun etc for bending , drainage valve, random 90 degree fittings possibly ..............................
Lots of variables involved.
