Watercooling Kits
10 Nov 2011
Boston, Lincolnshire
Hi Everyone. over next couple months i'll be working on my first watercool system.
Going from a HAF 922 to a HAF X which i get at the end of this month :D but at this current time i'm looking and shopping about on watercooling parts and dunno what to go for :confused:
I like the EK waterblocks for the CPU and GPU and in 2 minds about the Dual Bay Res... Dunno if to get an EK Dual Bay or a XSPC Dual Bay with the pump already in it?? I know one thing tho its got to be black so it doesnt stick out like a sore thumb on the HAF X..
Can anyone help me and give me some advice??
You shoud read about it a bit first. Then decide how much you can spend, do the list of components anf someone will give you advice if needed. One thing for sure - its really hard stick to the budget. I know something about it :) and probably others too.
If you're looking at the XSPC 750 Dual Bay Res you might find it a bit under powered for 3 blocks. Something D5 or DDC based would be an excellent choice.
It will be fine for just CPU. I had one for a while but I ended up switching to a D5 when the graphics card got added to the loop. Might be worth taking that in to account when ordering the parts.
cool cheers m8.. what pump parts would i need for an EK Waterblocks Pump??
