Hey guys, I was wondering if you wouldn't mind having a quick spec check of my what I'm hopefully about to order.
It's came that time, I've splashed soo much cash on the build so far my reasoning is that I may aswell go the full hog and watercool!
Its going to be mounted in new case etc.
Cooling my Q6600 in my sig which runs rather cold! (46 degrees on load with Asus Silent Knight II AL)
Hoping in future to introduce a graphics card into the loop in future... But could be some time before that happens.
Pump;
Laing DDC 18w Pump / Swiftech MCP355 £50.00
CPU Block;
Koolance CPU-350AC (CPU), Acrylic £71.99
Res;
EK Multioption RES 150 Rev2
Rad;
ThermoChill PA120.3 Radiator (15mm) £64.99
Water and Dye;
Feser Aqua 2000 ml £8.98
Feser Dye UV Invisible Blue £3.42
I know I've missed out the Tubing, because I'm currently not sure as to what size I want it to be... 7/16? I do want it to be rather thick. Any recomended brand?
As for Barbs, is 3/8 a good combination for this? Again, any recomended brand?
I really like the Koolance stuff but its rather expensive.
So what is everyones opinion on this and should I make any major adjustments?
Thanks
Pump;
CPU Block;
Res;
Rad;
Water and Dye;
Thanks
