I'm currently having a problem with the temps on my Gigabyte Windforce 7970Ghz ed. card. I've got everything cooled by air, but the temps on my card are running high and thus needing high fan speeds and causing an almighty racket. This is leading to the missus complaining every time I want to game.
So... I'm looking at options. If I could I'd just spec up a full water cooling loop and put both CPU and GPU under water to try and reduce noise, but I understand that the gigabyte card has no block available for it. So, what I'm wondering is, if I install a loop for the CPU, will that reduce internal temps in the case, and allow the GPU to run cooler? It would make sense to me that this would be the case, but in the real world does it work that way?
Any advice, or alternative suggestions are welcome.
