What is the best option for the following:
I am water cooling my cpu atm and am adding 2 full cover gpu blocks, i have made up two aluminium manifolds and am thinking of running flow into one manifold and diverting off three ways to the cpu and two gpu blocks. Then on return side they return to other manifold and back to res then pump then radiator ,then back to flow.
Would it be better to use manifolds or to loop tubing from cpu-gpu-gpu then back to res.
Im thinking using manifold all three blocks will get fresh cooled water rather than heated up water from previous blocks on looped system.
Manifolds have been made with 1/4 bsp fittings and inside of manifold is 14mm in diameter,they would be located on base of case.
Thanks in advance
Thanks in advance
