Hello WC fans!
I have seen some WC in this section systems and was really impressed! ...so I could really use your opinion on some things...so I created and account for this forum!
I am looking to watercool my system in order to be able to OC it but mostly out of fun ... that and, a friend of mine had a few things lying around so after years of not building a PC I have decided to get back into it!
Currently my specs are:
CPU: i7 920 D0 Lapped
Mobo: MB EVGA X58-SLI LE
RAM: Corsair 6Gb 1600Mhz CL8 in Tri-Channel
HDD: 2x 300 GB Maxtor 7200 RPM in RAID0
DVD: none, ...and I don't think I need one!
GPU: *temporary* 7900 GTX - so pls ignore
PSU: Fractal Design Newton R2 - 650W 80Plus
CASE: Fractal Design Define R3
What I already have from a WC perspective
Pump
Reservoir
Memory WB
Chipset WB
Rad 360
Potentially GPU WB if I find a GTX480
Things on the list I would add-buy
1* 250 GB SSD (currently deciding between Samsung ...and something else)
1* 2 TB 7200 RPM Drive
1* GTX480 (my friend has a WB he could send me) or GTX570/580 and buy WB
1* CPU WB
1* Clear tubing
3* silent fans
+ all the fittings/connectors/fluid+dye
Add another Tri-Channel Kit of 6 Gb? Is it worth it?
Some of the WB are clear/plexy so I will try to keep this pattern if possible to play around with some dyes for the fluid.
Generally, as the current case is white/black, mobo is all black, memory modules the same ...I will try to keep this as well a pattern and maybe keep everything: black/white/nickel. Esthetics are more important in my case than performance but I am not pushing it into the extremes meaning I don't want to spend an awful lot of money as I only play SC2 anyway. Also having the end-result as silent as it gets is one of my goals.
So, because it's kinda late > What key element did I miss ? What would you change ? I know the Case I have is not ideal for example but currently I am trying to sell my case and maybe PSU and get new ones; especially the case - I would like something that could take my 360Rad.
On the other hand I want to keep this as simple as possible in terms of money as my goal is to get the best out of what I have and not have better performance with newer components and the Rad can stay outside for a while =)
That said, even if I have to buy additional stuff as you can see I am targeting the second hand hand market to look for any bargains I can find to fit my little project.
A question to that: is there a section with ads here on OC UK and if yes what do I need to do there as a new user to trade? I saw some rules I think ...and can it be that I have to wait for a few months before being able to trade?
If that doesn't work, what other places than ebay and AVForum do you recommend especially for used WC stuff?
So what case would you recommend that could natively take my Rad or with a bit of modding and would suit my loop ? What loop would you recommend as I didn't see here too many chipset+memory+gpu+cpu loop examples?
I cannot post attachments yet so> Link: https://picasaweb.google.com/104531181966080324100/PC
If you look into the 3rd pic there, there is a wooden IKEA frame - I could temporary screw the Rad just left from where the case is with the vents down on pull.
Note:
As you can see I am new on this forum and new to WC, so if I say anything stupid please do feel the need to correct me and sarcasm is allowed =). Also, English is by far not my first/second language so correct me if I say something stupid...
Pump
Reservoir
Memory WB
Chipset WB
Rad 360
1* CPU WB
1* Clear tubing
3* silent fans
Note:
