I'm looking to put my pc under full watercooling since my 2080ti is running way too hot on air in this case, but I'm not entirely sure what would be the best way to go about it? Since the space is very limited, I think it'll be very difficult to fit two slim 240mm rads in there with a pump too, I have seen a few builds do this online, but I'm still not 100% on how to do this since I have a 240mm aio (although it is a thicker rad) in there now and spacing is very tight.
I'm hoping to reuse as many components as I can, I currently have an EK full nickel cpu block, darkside 240mm slim rad and an EK pwm ddc pump that I think should be ok to fit in there. I was also planning on getting the reservoir that is designed for this case to put in.
My main questions for this would be, whether its better to go for external or internal for radiators? And what would be the best approach to take?
