Watercooling Newbie (Help)
9 Aug 2010
Hello,
I finally got the courage to do my first watercooling build and I was wondering does these parts look correct?
My goal is to OC my CPU to 4.5ghz and have silent operation is my parts suited for this?
Bitfenix Prodigy
Intel Core i5-3570K 3.40GHz
Asus P8Z77-I Deluxe
256GB Crucial M4
Crucial Ballistix Elite 8GB
Corsair AX650w
GTX 670
BitFenix Recon Internet-Connected Fan Controller
XSPC RX240 120mm Radiator
Scythe Gentle Typhoon 120mm 1850 RPM X2
XSPC RayStorm CPU Block
XSPC Razor GTX 670
XSPC HighFlex Hose clear 1/2" ID, 3/4" OD
XSPC Coin Fit 1/2 ID 3/4 OD Compression Fitting - Chrome
Mayhems X1 UV Blue Premixed Watercooling Fluid 2L
Angle fittings
Laing D5 Vario Pump
EK-DDC X-RES 100
What's a EK-DDC X-RES 100 when it's at home?
The pump you have selected is a D5, and the EK-DDC X-RES sounds like a reservoir that mounts onto a DDC pump.
D5 pump....
no top...
http://www.overclockers.co.uk/showproduct.php?prodid=WC-055-AC&groupid=962&catid=2141&subcat=
With "Top"
http://www.overclockers.co.uk/showproduct.php?prodid=WC-004-SW&groupid=962&catid=2141&subcat=
DDC Pump...
10W model
http://www.overclockers.co.uk/showproduct.php?prodid=WC-005-SW
18W model (900lph)
http://www.overclockers.co.uk/showproduct.php?prodid=WC-002-LA
18W model (600lph)
http://www.overclockers.co.uk/showproduct.php?prodid=WC-047-AC
The res needs to fit the pump....
I am going to order the following can someone please see if its correct and will work with each other?
Bitfenix Prodigy
Asus P8Z77-I Deluxe
256GB Crucial M4
Corsair Vengeance Blue 8GBDDR3
Corsair AX650w
OcUK Tech Lab H2O Custom GTX 670 2048MB GDDR5
Apogee Drive II
Swiftech MCRES Micro Revision 2
XSPC Coin Fit 1/2 ID 3/4 OD Compression Fitting – Chrome
Mayhems X1 UV Blue Premixed Watercooling Fluid 1L x2
Will 1 radiator be fine for a 3570k(4.5ghz) and 670(stock)? and do I need any additional fans in the case or can I get away with what I said above? My goal is silence :)
Cheers
