Hi All,
I think I might finally take take the splash and go proper water cooling.
Splash... gettit
I currently have an i7 920 with an Asus P6tSE mboard using a corsair H50 to cool the cpu.
I've just purchased a gigabyte GA EX58 motherboard that has built in watercooling for the chipset and seeing as my overclock (4.0Ghz) is pretty much temperature limited (I've had it at 4.2 but temps were too high) I thought maybe I should just watercool the cpu and motherboard properly.
So my component shortlist currently is:
XSPC X2O 750 Dual Bayres/Pump (Black) V4 £59.98
(£49.98) £59.98
(£49.98)
EK Water Blocks EK-Supremacy Clean CSQ £51.95
(£43.29) £51.95
(£43.29)
EK CoolStream Radiator XT 360 (120.3) £48.98
(£40.82) £48.98
(£40.82)
I guess what I need to confirm is what type and number of fittings I'll need and what would be the best tubing type/ size etc.
Recommendations on fan type for this rad.
I'll be fitting all of this into a Slilverstone TJ10, so will be modding the top of the case to take the rad etc.
Any help much appreciated!
E-I
Splash... gettit
(£49.98) £59.98
(£49.98)
(£43.29) £51.95
(£43.29)
(£40.82) £48.98
(£40.82)
E-I
