Hi,
I am seriously looking into watercooling at the moment.
The setup im looking at will have a laing dcc pump, and an xspc rx360 radiator.
I am currently using a true with a 1200rpm noctua fan, inside a p182 case with the three stock fans. These fans are set to medium when i am gaming. Whilst browsing web and watching movies i have them set to low. This is at 4.0ghz overclock with highest stability test temp being about 81-82 degrees(hence looking into watercooling). I do not intend to overclock any more than this.
I was wondering, in comparison, how loud the watercooling setup will be? Will it allow me to turn off the two fans at the top of my p182, leaving just the front intake blowing over my gfx card at better temps than my current setup?
If i set my clock back to stock, would i be able to turn the fans off on the watercooling and still acheive acceptable temps?
Thanks,
Phil.
Thanks,
Phil.
