Hi All, Hopefully you can help I’ve recently decided to join you all on the water-cooling side for my new build, been new I decided to try and get the best for each part but I’ve made a few mistakes I think, the first one got the wrong side radiator from blackice way too big for my rig, the second I’m not too sure about so I’ve come here to find out, I’ve just got 2 OcUK Tech Lab - D5 Vario Pump & EK D5 X-Top V2 Value Combo Units to go with a Koolance RP-452X2 Dual 5.25" Reservoir for 1 or 2 D5 Pumps Rev 1.2 but how do they go together it looks like the pump goes in the Reservoir, but not sure as my pumps don’t look like they will connect to it, Koolance say I need the D5 Vario Pump but do I need it without the TOP not sure? Talk to Overclockers Tec already he said if I talk to you guys first and if I have made a mistake then I can send it back to get it without the top but said it was best to ask you first.
Many Thanks in advance.
