hi all as the title says im a noob at watercooling, as in never done one yet.
ok i have 2xgtx 480 sli, and they are getting a bit hot due to the fact my tower is under a bench and the hot air has no where to go so its getting sucked back in the case by my large fan on the top of tower.
so i was thinking of getting water cooling for the gpu's, i already have a corsair h50 for the cpu and temps are fine there.
what would i need for best cooling, sound is not a problem as its under a bench in a room at the back of the house.
and also does the rad for the watercooling go inside the case or mounted outside the case, i currently have an antec 1200 case, i7 930 with h50 cooler, 2x gtx480, 1x 2gb hdd, 2x 80gb intel ssd's, gigabyte ud5 m/b, 1000watt psu.
any help/guidance would be appreciated
