- 22 Jul 2009
Hi guys,
computer is starting to sound like a hair dryer with all the fans I've got so going down the watercooling route now. Need some help with it as doing an upgrade at same time and water cooling is built into some of the new components.
To start off with, I'm thinking about using the Zalman Reserator XT Hybrid
http://www.overclockers.co.uk/showproduct.php?prodid=WC-011-ZA&groupid=701&catid=193&subcat=
Motherboard will be Asus Rampage Extreme Intel X48
http://www.overclockers.co.uk/showproduct.php?prodid=MB-284-AS&groupid=701&catid=5&subcat=1050
and looking at the photos on this website (and scrolling further down), it looks like something is watercooled:
http://uk.asus.com/product.aspx?P_ID=auuHEruiFYpvdxNw&templete=2
What is it? Do I still need something on the CPU and what does Northbridge/Southbridge and VRM stand for? Seriously novice questions, I know, sorry!
Also planning on this video card, Gainward GeForce GTX 295 1792MB GDDR3 PCI-Express:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-107-GW&groupid=701&catid=56&subcat=1324
cooled by this:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-029-EK&groupid=701&catid=193&subcat=1035
Will the connectors between the Zalman Pump, the motherboard, the VGA cooler and anything else I need be the same, and if it isn't what do you recommend?
And lastly, if you can suggest any extra coolers/heatsinks to fit to the water cooling system, go for it.
Thanks in advance.
cooled by this:
Thanks in advance.
