Watercooling O-Rings
7 Feb 2004
North East
Been out of the w/cing loop (no pun intended :p ) for a long time now and have noticed all barbs seem to ship with o-rings. Are these a suitable seal and do they deteriorate at all ?
No-one use PTFE tape anymore ?
Im tempted to get some anyway for peace of mind, but any opinions ?
I used ptfe with my most recent build but i was using 2nd hand barbs so didnt want to risk it. They shouldn't leak but only takes a few more mins so why not.
The o-ring barbs are perfectly safe without PTFE providing you get ones with a retention groove for the o-ring to fit in. With these you can screw the barb down very tightly whereas without it there's always the change the o-ring will get squeezed out from under the barb when you tighten it up.
