Watercooling order
14 May 2012
I'm currently rebuilding my loop and I have a question:
I'm questioning the order of my components.
So The res is above the pump, this then pumps the liquid through the mid-plate.
From here things get questionable.
So the 2 radiators for the GPU loop are under the mid-plate. the GPU's are above the midplate.
And the one of the Mobo blocks is included in the same loop.
Therefore my question is this:
Does it matter if I go Res -> Pump -> Rad 1 -> Rad 2 -> GPU 1 -> GPU 2 -> Mobo -> Res -> etc.
Over:
Res -> Pump -> GPU 1 -> GPU 2 -> Mobo -> Rad 1 -> Rad 2 -> Res -> etc.
